Hello i purchased a stock 07 xt manual 5 speed sport with tien coilovers at 52k miles, heres my current build that i have installed, if you have any questions on install process please feel free to ask
how it looked when i first purchased the car
Red - removed from car
Green - install guide linked
Blue - picture links
install guides:
Rear wiper arm delete
Future mods:
Subtle Solutions Fender Brace Set (SUS-9001-SLV)
Kartboy Front Endlinks (KB-017-F)
Kartboy Rear Subframe Lockdown (KB-066)
STI TRAILING LINK SET (ST2027055000)
LAILE (Beatrush) FRONT PERFORMANCE BAR(S86010PB-F) - need to adjust power steering lines due to not clearing
subtle solutions fender brace
mods that either dont fit or removed:
-JDM REAR DIFFUSER + CUSCO BAR - cusco bar doesnt clear whiteline rsb mounts, will have to cut part of the cusco bar in order to fit the rear diffuser
-Sti clutch line (ST372514S000) - Doesn't fit
-SYMS clutch (Y100199004) and brake cylinder cap (Y100199003) - doesn't fit right
-Company23 Vacuum Tee Kit (COP 526)
Maintenance: Free Service Manual for 2007 xt
Replaced valve cover gaskets - hardest part was taking off the old liquid gasket -10/25/16
Engine:
5w30 Eneos Sustina oil
Mishimoto liquid chill radiator fluid
Cobb AP stage 2 - 3/27/14
protune by church automotive
My Dyno chart 1
My Dyno chart 2
Cobb Downpipe - 3/27/14
Cobb SF intake - 3/27/14
Grimmspeed heatshield - 3/27/14
Nvidia G200 catback exhaust (INV HS04SFRG2S) - 3/27/14
Sti oil cap (STI ST15257ZR010) + radiator caps (STI ST4511355010) 3/27/14
Jdm alternator cover (190-023-002) - 6/18/14
Koyo radiator (KOY VH13026) - 6/18/14 - a lot of aftermarket radiator shrouds don't fit like my old subtle solutions one. The beatrush one clears Koyo per another member
Cusco radiator shroud[/URL] (676-003-AL) - 6/18/14 - slight modification just by making a hole a little bigger to fit koyo radiator
Crawford v2 AOS (CRA S0714B) - 7/9/14
Process west tmic and jdm splitter (PRW PWTMIC09) - 2/27/16
HKS earth grounding kit (HKS-48004-AK001) - 3/12/16
Optima yellowtop battery (8020-164) - 3/23/16
GFB hybrid BOV(GFB T9003) - 3/28/16 - you will need to shorten the bolts down with a dremel and filer in order to fit on the PW TMIC
Six Star Armor radiator brackets - 4/1/16
OEM clutch cylinder and slave replacement - 4/6/16
Goodridge stainless steel clutch line - 4/6/16
Competition clutch stage 2 (CCI1 15026-2100) - 4/8/16 - installed by Uehara Motowerks
Company23 TMIC Stud Kit (COP 508) - 10/22/16 - upgraded to these so i don't strip my PW TMIC holes
GrimmSpeed Master Cylinder Brace (GRM 091016) - 10/23/16 - Had to delete my secondary air pump due to it blocking the way of the brace
LIC Motorsports Air Pump Delete Plates (LIC 073109) - 10/23/16 - need to remove intake manifold to remove passenger side air pump tubing,i left the sensor bolted on and plugged in
IAG TGV delete - 10/28/16
Cosworth Thermal Intake Manifold Gasket (COS1 20013283) - 10/28/16
GrimmSpeed Intake Manifold to TGV Gaskets (GRM 023001) - 10/28/16
Injector Dynamics 1000cc - 10/28/16
STI Oil Cooler - 11/5/16 - needed this to fit killer b headers
Perrin Turbo Inlet Hose Black (PER1 PSP-INT-401BK) - 11/5/16 - fitment is pita due to it rubbing against the power steering pump, i would recommend a different brand
Perrin coolant overflow tank - 11/5/16
COBB Tuning Post MAF Silicone Hose Black(COB 712010BK) - 11/5/16 Had to replace oem plastic hose due it not fitting the intake with the new perrin turbo inlet
Group N Transmission mount - 11/10/16
Group N pitchstop (STI D1040FE000) - 11/10/16
Group N Engine mounts - 11/10/16
Tomei 7760 turbo (TOM 173016) - 11/10/16
Killer b oil pan - 11/10/16
killer b pick up/baffle
Killer b holy headers (KIL HH4-1) + up-pipe (KIL PPBC) - 11/10/16 - needs sti oil cooler to fit
Killer B Motorsport High Flow Water Pump Housing(KIL WPH) - 11/10/16 - removed due to poor fitment with timing belt cover
DW200 fuel pump (DET 9-201-0791) - 11/19/16 - i forgot to buy the inline filter,i thought this kit included one but that was only the pre filter. i will have to redo this install a later time, kinda pita to take out the fuel pump from gas tank.
Mishimoto Coolant Expansion Tank Black(MIS MMRT-WRX-01EBK) - 11/20/16
Company 21 boost controller (COP 522) - 11/20/16
Titanium Dressupbolts
Exterior:
Jdm front skirt lip (190-106-001) - 2/20/16
Jdm sti rear bumper (190-022-001) - 2/27/16
Jdm 02-03 sti hood scoop (009-478-003) - 2/27/16
Jdm sti badges (190-045-001) and rear (190-046-001) - 3/12/16
Jdm front and rear pods (190-118-003-B) and (190-118-003-A) - 3/20/16 -
Cobb license plate frame - 3/20/16
Cobb front plate delete - 3/20/16
JDM SG9 rear spoiler with brake light (Japanparts No : 190-006-004) - 9/11/16
JDM side visor (Japanparts No : 190-017-001) - 10/19/2016
JDM waist spoiler - 06/01/17
Thule motion XT box with thule aeroblade racks - 06/01/17
Subaru OEM Carbon Fiber STI License Plate (SOA342L145) - 06/01/17
Password jdm rear wiper delete 01/01/18
Interior:
2005 wrx seat swap with oem rails,seat belt and heater - 7/6/15
Jdm anti static plate (107-021-001) - 2/20/16
Weathertech floorliners (441281-440972) - 2/28/16
Clarion nx405 headunit - 3/6/16
Polk db651 6.5" front speakers - 3/6/16 - modified crutchfield bracket to fit
Polk db401 4" rear speakers - 3/6/16 - modified oem speaker bracket to fit
Jbl GTO19T tweeters 3/4"- 3/10/16 - modified oem bracket to fit, i wouldn't recommend any size bigger than 3/4"
Jdm sti s-edition's black panel set (190-025-L) - 3/12/16
04 Sti 5x100 donut - 3/12/16
Jdm shift ring and boot (ST921294S220) - 3/23/16
2013 Sti shift knob - 3/24/16
Sti sun shade with steering cover (STSG13100020) - 3/25/16
Damd steering wheel(SS358DF) w/ sti airbag - 3/27/16
Weathertech cargo liner - 3/30/16 - this thing is garbage don't buy it - going back to OEM cargo tray
Kartboy short shifter (KAR KB-001-LEG) - 11/20/16 - had to cut out a portion of the bracket with a dremel to fit this, it is not direct bolt on.
Innovate PSB-1 gauge(INN 3892) with solidmod vent pod - 03/01/17
STI SIDE SILL (94060B/ 94060C) - 07/01/17
Lights:
Diode Dynamics hid kit and interior led kit - 4/13/14 - plug and play
Morimoto taillight leds - (7440) rear turn - (7443) x2 rear brake - (T15/921) ACME reverse light - 3/25/16 - I did not install a turn signal resistor which prevents hyper-flashing, i like that it hyper-flashes with all these baddie drivers out here.
Sg5 taillights - 3/25/16 - I didn't know there are only 3 bulb holes on the jdm ones, you will need to manually cut out a 4th hole for the 4th bulb or get USDM ones which should have 4 holes.
DEPO SG5 LED Tail lights (TL-SU-FOR-03-DP-LED-RC) - 9/11/16 - replaced the oem sg5 tail lights
DEPO SG9 SPORTS HEADLIGHTS- 07/01/17 - had to replace the oem ones due to it leaking
Suspension:
Kartboy shifter bushings (KAR KB-003) and (KAR KB-003-REAR) - 3/27/14
Tien coilovers which came with car
used 06 STI Brembos calipers front and rear - 5/15/16 - I replaced all the seals and added speed bleeders
04 STI front centric premium rotors - 5/15/16
4k rotor rear and Brembo adapter brackets - 5/15/16
GoodRidge G-Stop Stainless Steel Brake Lines Front/Rear (GOO 24215-CL) - 5/15/16
Cosworth Streetmaster Brake pads front (COS1 CFS3004) and rear pads (COS1 CFS3008) - 5/15/16
04 sti steering rack - with superpro steering rack bushings - 03/01/17
LAILE (Beatrush) Rear Diff Mount (S76010MTD-RS) - 07/01/17
LAILE (Beatrush) REAR PERFORMANCE BAR (S86010PB-R) - 07/01/17
LAILE (Beatrush) FLOOR PERFORMANCE BAR (S86203PB-CR) - 07/01/17
LAILE (Beatrush) STRUT BRACE REAR (S86203-RTA) - 07/01/17
STI LOWER ARM BAR (ST205104S020) - 07/01/17
Kartboy Rear Drop Endlinks (KB-017-STI) - 08/01/17
Whiteline Rear Sway Bar 22mm Adjustable (BSR35XZ) - 08/01/17 - the Subaru Forester Rear Link Support that comes with the swaybar doesnt fit the arms
Whiteline Rear Sway Bar Mounts (KBR18-22) - 08/01/17 - doesnt fit cusco bar for rear diffuser, the bar has to be modified to fit
cusco rear power brace - 1/1/18 - feels usless, maybe extra crash protection from the rear
Wheels:
19x8.5 +35 5x100 PIAA - old wheels
18x9 +45 5x100 Volk te37 sl pressed graphite w/ Iconix lug nuts - toyo 4 plus tires 245/45/18 - 1/29/16
install guides:
Future mods:
Engine:
My Dyno chart 1
My Dyno chart 2
Exterior:
Interior:
Lights:
Suspension:
Wheels:
