I came from an '05 STi that I raced STU very successfully in the ARSCCA Solo II and a little in Solo I. Blah blah blah, I wanted more room for camping and biking so I got a Forester and had big plans! I'm dead set on building up a Forester STi all the way from full STi interior to a 5x114.3 swap. Think Angry Toaster built as an '07 Sport...
It started in June '08 when I bought this: FS: 2007 FSXT 5 Speed(STI Replica) in Florida The PO had some nice parts on it... • IHI VF39 • STI TMIC • Brembo STI Front Big Brake Kit with Brembo slotted rotors • STi Rear Sway Bar • Swift Springs • APS Turbo Back (needed to be reworked to fit) • HID Conversion • STI Rear tail lamp swap • STI WRB Hood Scoop • Rear factory wing because I knew I wanted a Sport. There weren't may around so I didn't have much choice. I wish I could have found a WHITE one... those are so incredible. All I knew is that I didn't want blue on gold. :unamused: But the blue is growing on me. ![]() Here it is as I bought it. A few parts I could use, and a few things I knew I'd have to change. I autoXed it like this ONCE and only once. Wow... it was like driving a motor home. The brakes were terrible, the power wasn't smooth, it rolled all over, tires wouldn't hold at all... I'm not a fan of putting STi stickers on something that isn't (yet), so those came off. I also didn't like having glittery gold calipers so I painted them black. I also added the H6 kit, SS lines, and an STi master cylinder. Mucho big improvement!!! I also pulled off the 5% window tint because it's illegal and I couldn't see past sunset. ![]() Now that the brakes were better, I ripped out the super crappy Delta system and went with an AP V2. I also bumped up the front sway to a 27-29, added some rear subframe lockout bolts, the WL rear control arm/swaybar helper thingys, and WL rear spherical endlinks. Then I painted the headlights with black ceramic paint. It was a PITA to do, but worth it. I also bought the original Forester Sport grill badge. ![]() ![]() WORK EMOTIONS!!! ![]() Some camping shots enjoying the utility of the Forester... ![]() ![]() ![]() ![]() Last edited by mmtasty : 02-11-2009 at 04:40 AM. |
So I tracked down a set of '07 WRX struts, springs, and tophats. I swapped those over and like the improvements, but wanted to to go lower eventually. These photos are before/after compared to stock struts and Swift springs vs. WRX stock everything and Paranoid Android 3/8" spacers in the rear:
![]() ![]() ![]() Now that I'm on WRX struts I can use lower lowering springs without bottoming out the struts. Also, it does seem to ride a little firmer and have less lift/sag at a WOT start. Overall I guess it's a good thing to do with minimal money and an hour of time. Then I got tuned... ![]() And now my clutch is slipping in 5th at boost... It would go higher with HP, but the fuel pump is maxed, and could go bigger with torque, but the clutch will slip (note the lower graph with wheel speed vs. engine speed). So I'm saving for the 6 speed, but that doesn't keep me from doing a little more handling improvements as budget allows. I added an '04 STi steering rack, WL rack bushings, WRX Eibach springs, WL camber plates, and 235/45 Direzza Star Specs. ![]() Last edited by mmtasty : 02-10-2009 at 04:15 PM. |
#7 (permalink) | |
Thanks everyone!
Not even close! Incredible! A HUGE PITA, but it was worth it to me. I got my rack shipped for $210 FYI. And also note, if you autoX, you'll find that the stock power steering pump can't keep up on massive Left/Right/Left wheel maneuvers. You'll need an STi pump if so, but that's no biggie. |
#13 (permalink) |
Looks great ! Since you auto-x and have done the mods I have a few q's for you
1) 27-29mm front sway bar: Is that a Whiteline ? And why so large , while I'm a bigger is better fan I as aiming at getting the 24mm bar. Yes it does plow somewhat at the auto-x, not so bad at track days. What are you running for sways in the rear ? 2) STi steering rack & power steering pump : I agree our rack sucks. I drove my friends 06 STi and it feels like 2x more sensitive. I have an 06 STi rack to install this spring so the power steering pump comment is interesting. Exactly what parts do I need , just the pump , or parts like the resevoir.... parts list (or pics even better) please 3) Bike rack: Looks like a Thule folding rack you've got there. I have an OEM hitch to put on and want a rack like yours. What's teh model number and do you recommend it ? Pics of it with pics on the back ? Shame you're not local, would be fun to have two WRB Foresters battle it out at the auto-x. |
#14 (permalink) | |
I've tested all different configurations and settings with these bars at autoX and track events: stock, full Cobb/Hotchkis F/R bars, 32mm Strano bar, 24/26 WL front, 27/29 WL front (perfect), STi rear (perfect), Wagon rear, and a 24 rear that I forget the brand...Perrin maybe? And a large variety of endlinks. Test vehicles were my old '03 WRX, '05 STi, and now my Fozzie. PLUS, I've helped wrench and setup several other friend's cars. The only friend that wasn't happy with their rotation insisted on a 26 front and 24 rear... 2) You'll need the subframe to put that '06 rack. The '04 is a bolt in, but the '05+ changed. Shouldn't be any more difficult. Maybe even easier... I haven't swapped the pump out yet, but it should be a bolt-in. I think all you need is the pump. 3) it's a Thule. That's the only decent upright one that has a lever to fold the rack down for access. That's why I got it. I love it. Other racks you have to fool with pulling a pin and clippy thing which is a PITA when you have 6 bags of groceries or a hyper dog that wants in. Too bad you don't live closer so we can battle! The SUV does get a lot of attention out on course... |
#15 (permalink) | |
