I bought my Forester from the previous owner in April 2015, he had imported in in October 2014 and had done some work to it before I bought it. It had 58,890 kilometres on in when I bought it.
As it sits now:
Work completed by previous owner:
Brake pads/calipers.
Timing belt, idlers etc.
Valve cover gaskets.
Spark plug cover gaskets.
Gromets.
Positive crankcase ventilation gaskets.
Half moons.
Oil pick-up o-ring.
Oil pick-up.
Replaced all fluids
Spark plug wires - Magnecor PN 45205
Spark plugs.
OEM block heater
Air filter and cabin filter.
Removed suspension and rustproofed fender liners, removed side skirts and did the same.
Replaced rear wheel seals/bearings.
Want to do:
Install after-market stereo - Done
Replace factory speakers - Done
Add amp/sub - Done
Upgrade rear sway bar, bushings and endlinks - Done
Install Oil Pressure/Boost gauge - Done
Add cruise controls.
install heated seat kit.
maybe after-market exhaust, however the current one is in mint shape so I'm leaving it for now.
As it sits now:
Gromets.
Half moons.
Oil pick-up o-ring.
Oil pick-up.
Replaced all fluids
Spark plugs.
OEM block heater
Want to do:
Add amp/sub - Done
