Transmission and Driveline etc.
Rallispec Cryo treated long gear 6 speed transmission
New oem center section and bellhousing.
2005 STi Transmission Crossmember
Spiider DCCD Pro
2005 STi Axles
2005 STi Front and Rear Hubs 5x114
2005 STi Drive Shaft
2005 STi R180 Differential & Mount (new Whiteline Bushings)
2005 STi Rear Subframe and alluminum Lateral Links
2005 STi Trailing arms
2005 STi Rear Crossmember
New STi Forged Aluminum control arms
2006 STi Steering rack
WRX STi Subframe Bolts for spacer delete
EIBACH 25mm front, 25mm rear adjustable sway bars
Agency Power End Links
Competition Stage 4 - 6 puck clutch
Competition Clutch Lightweight Flywheel
Whiteline Rear Differential Bushings
Whiteline Rear Diff Crossmember bushings
KARTBOY Transmission Mount Bushings
Perrin Transmission mount
2011 STI BBS wheels
255/35/18 Federal RsRR
Engine and Other
EJ25 Built block
LA sleeves
Brian Crower I beam Rods
STI nitrited crank
CP 100.5mm Pistons
King Tri-Metal Race Bearings
Ported heads
Supertech +1 sodium filled inconel valves.
BC stage 2 272 Camshafts
ARP 625+ Head Studs
Borg Warner EFR7670 Rotated Twin Scroll Turbo Kit, Internal Wastegate
FULL RACE Equal Length Headers
FULL RACE Twinscroll Up pipe
FULL RACE Catless Downpipe
Grimmspeed TMIC and Splitter
Grimmspeed AOS
KOYO Radiator
Accessport V3
DW300c Fuel Pump In Tank
AEM 400IL From Surge tank
Custom 2L Surge tank
ID1700X Top Feed Injectors
IAG Top Feed Fuel Rails
Stainless Steel Russell Braided Parallel Fuel lines
Aeromotive FPR
Russell Fuel Filter
Killer B Oil pan
Killer B Oil Pickup
Killer B Oil Baffle
BEATRUSH Engine mounts
Perrin Pitch Stop
IAG Billet TGV Deletes
Brakes
2005 STI Brembos
Stoptech Brake Lines
STi Brake Master Cylinder
STi Brake Booster
Grimmspeed Brake Master Cylinder Brace
Exterior
Cross sports Front Bumper and Grill
Red/Black Carbon/Kevlar Syms spoiler
Red/Black Carbon/kevlar JDM style waist spoiler
New Right and Left Fenders
2002 JDM WRX STi Hood scoop
CNC Machined JDM "F" Emblem License plate delete
Grimmspeed Forester Specific Hood Struts
Retrofit Headlights
-Morimoto D2S Bi-Xenon Projectors
-Morimoto Mini H1 Bi-Xenon Projectors
-Morimoto square halos
-Morimoto RGB Halos
-Morimoto RGB Demon Eyes
-Painted Housings and Shrouds
Interior
Full Interior Dynamat
2008 STi Front Seats
Android Nexus 7 dash mounted tablet
Pioneer AVH-2800 Double Din
Rockford Fosgate 1000w 5 channel amp
Boston Front and Rear Speakers, front crossover to Boston tweeters. New wiring to underseat amp.
JBL 10" free air subwoofer built in stock sub location
2004 STi Gauge Cluster
STI Pedals
PODI subaru color match gauges. Boost, Oil Pressure, Wideband.
Ortiz Pillar pod
Links to pictures and build info
Cleaning Transmission and Differential
Painting Sports Grill
New Turbo Photos
Headlight Retrofit Begins
Full Dynamat
Painted Rear Hatch Trim
Wilwood Front Brakes
2004 STI BBS
Three Forester Driveway
Spiider DCCD Pro
Footwell Red LED
BC 272 Cams Arrived
Eibach 25mm Front and Rear Sway Bars Arrived
Interior Trim Painting
LED Tail Lights
Heads Back From Machine Shop
STI Brake Booster and Master Cylinder
Eibach Sway bars Installed
Brembo Rear Brakes
2008 STI seats
Subtle Solutions Fender Braces
Sexy Turbo Kit
Head Studs In, Heads Torqued
Spiider DCCD Pro
2005 STi Axles
2011 STI BBS wheels
Engine and Other
EJ25 Built block
LA sleeves
STI nitrited crank
CP 100.5mm Pistons
Ported heads
ARP 625+ Head Studs
Grimmspeed AOS
KOYO Radiator
Accessport V3
Aeromotive FPR
Russell Fuel Filter
Killer B Oil pan
Killer B Oil Pickup
Killer B Oil Baffle
Perrin Pitch Stop
Brakes
2005 STI Brembos
STi Brake Booster
Exterior
Retrofit Headlights
-Morimoto RGB Halos
Interior
STI Pedals
Ortiz Pillar pod
New Turbo Photos
Full Dynamat
2004 STI BBS
Spiider DCCD Pro
Footwell Red LED
BC 272 Cams Arrived
LED Tail Lights
Brembo Rear Brakes
2008 STI seats
Sexy Turbo Kit
