Advertisement |
#32 (permalink) |
Need more MODs! Contributing Member
Hmmm... I just noticed.
![]() Bobby...
'07 FSXT WRB AT - COBB dyno Protune - Stage 1 '03 X PBP AT +AVO turbo kit! (son's) '95 Neon Sport |
#34 (permalink) | |
I can't even drive right now. Since I bought it out of State, they gave me a 3 day trip permit. Now I have to wait for the title so I can get the vehicle inspected & licensed with the DMV... I can hardly wait to stand in line for this chore. ![]() Bobby...
#35 (permalink) |
The Sub kit guy
Hey Ian-
What are you doing helping steal one of our states only WRB XTs? Bobby- When I sold my Impreza, it took the State over 3 weeks to send the title out.
#36 (permalink) | |
![]() Bobby...
#38 (permalink) | |
![]() Bobby...
'07 FSXT WRB AT - COBB dyno Protune - Stage 1 '03 X PBP AT +AVO turbo kit! (son's) '95 Neon Sport Last edited by 2.5x_sleeper; 07-21-2009 at 10:55 PM. |
#39 (permalink) |
Here's the family. Left to right. '07 FSXT, '03X highly MODded with an AVO turbo kit & now our back up car, a lightly MODded '95 Neon Sport.
![]() Bobby... ![]() The Table of Contents for my Member Journal can be found
'07 FSXT WRB AT - COBB dyno Protune - Stage 1 '03 X PBP AT +AVO turbo kit! (son's) '95 Neon Sport Last edited by 2.5x_sleeper; 02-15-2010 at 10:03 AM. |
#40 (permalink) |
Good lookin' car. Looked just like mine 2 1/2 years ago. I have a used set of OE WRB mud flaps that I want to get rid of, 6k miles on them. I'm actually headed to Portland next week. PM me if you're interested.
MY07 WRB FSXT MT bobbytuned MY00 SR OBS AT |
#41 (permalink) | |
![]() Bobby...
#43 (permalink) |
The MODding list starts...
![]() Bobby... The Table of Contents for my Member Journal can be found
'07 FSXT WRB AT - COBB dyno Protune - Stage 1 '03 X PBP AT +AVO turbo kit! (son's) '95 Neon Sport Last edited by 2.5x_sleeper; 02-15-2010 at 11:51 AM. |
#44 (permalink) | |
Besides, after driving 200+ miles & having to drive it again, we just wanted to get the business done & go home. ![]() Yes, the styling change does make the later model look bigger, but if you compare my '03 with the '07, you can see how they just extended the nose over the bumper, which makes it look longer... lots more plastic! ![]() Bobby...
'07 FSXT WRB AT - COBB dyno Protune - Stage 1 '03 X PBP AT +AVO turbo kit! (son's) '95 Neon Sport Last edited by 2.5x_sleeper; 07-21-2009 at 10:56 PM. |
#45 (permalink) |
MOD #1 is complete!
![]() Okay, the big day is here! It's much cooler today, so I can do the installation outside in comfort. This will be the first MOD to my recently purchased '07 FSXT! The Scangauge II is a nifty device that I would not want to be without. Other than finding a place to mount it, it's pretty much plug & play. ![]() To see how I fabricate the mounting bracket & how to attach the the Scangauge II to the bracket, view my write up here for my '03 X. ![]() Bobby... For my installation, the Scangauge II cable needs to be routed behind the gauge cluster trim. 2 screws need to be removed. The bottom just clips in. Once the screws are removed, it will pull right out. Dropping the steering wheel down will make removing the dash gauge cluster trim easier. Don't force it, it will come out easily once you have it oriented correctly. ![]() The dash bottom panel also needs to dropped down to ease the routing of the Scangauge II cable. There are 2 screws on the bottom & the top just clips on. After removing the lower 2 screws, pull the top loose & let it hang down. Use a pair of side cutters to clip a small amount off the left side of the gauge cluster trim, where the Scangauge II cable will pass thru. It's better to remove too little, than too much. ![]() ![]() Use a file to smooth the cut end & do a test fit. It may take several test fits before it's just right. When it's right, the Scangauge II cable should still be able to move when the gauge cluster trim is reinstalled. The right picture shows the trim is reinstalled & the cable ready for the Scangauge II. ![]() Plug in the ScanGauge II & slide the bracket into the dash. It should be noted here, for security, the Scangauge II can be removed in just a few seconds & only the cable end will be visible. The right picture shows the Scangauge II installed. ![]() The left picture shows the installed Scangauge II in operation. The right picture is shot from farther back. ![]() The Scangauge II cable is longer than you'll need. I just rolled up the excess & tied it up under the dash to keep it out of the way. ![]() The Table of Contents for my Member Journal can be found
'07 FSXT WRB AT - COBB dyno Protune - Stage 1 '03 X PBP AT +AVO turbo kit! (son's) '95 Neon Sport Last edited by 2.5x_sleeper; 03-08-2010 at 09:49 AM. |
| Thread Tools | |
