Last night our "check engine" light went on with the code P0420 on our 1999 Forester (127k miles). An independent mechanic checked it out this morning and says the two O2 sensors are fine, so he's recommending replacing the catalytic converter. He's also recommending replacing the O2 sensors. The total cost would be around $1150. He did say that it's not urgent and that I can probably wait until the next smog test.
1) According to a little printout from Autozone (I borrowed the engine code reader from them), P0420 could be caused by other things. My mechanic seems pretty confident the catalytic converter is the problem. Is it worth getting a second opinion for $50-60? 2) Is there a way to do this cheaper? I see posts by people saying I can get a universal catalytic converter put in for half the price. Is this possible in California? Are there any drawbacks to this? Can this be a DIY job if I get right kit? (I don't want to do any welding myself). I'll call some muffler shops when I get off work but I thought I'd ask here while I'm at work...... Thanks. |
Need more MODs! Contributing Member
Sounds a bit high to me! I had a high flow replacement CAT installed in MY03 by a trusted muffler shop for $200. I'm very picky, so I watched the entire installation & it was "perfect".
You could get a rear O2 sensor for $100 or less & install it yourself. The rear sensor is pretty easy to replace. Unless you weld & have the tools to size the pipe, the CAT is not DIY! The rear O2 sensor only monitors the efficiency of the CAT & doesn't affect the engine operation. If your Forester is running poorly, there could be a problem up stream (A/F.. air/fuel, front O2 sensor, this sensor is critical) & that could be overwhelming the CAT so it's letting too much O2 pass thru & this is being detected by the rear O2 sensor... CEL code P0420... A thought... how about addressing the rear O2 sensor first? If that corrects the problem, you're only out the cost of sensor. If it doesn't correct the problem, you were going to replace the CAT & the rear O2 sensor, so you're still not out anymore than you were going to be... Bobby...
2007 WRB FSXT 4EAT 2003 PBP 2.5X 4EAT +AVO turbo kit! (son's) 1995 Neon Sport (spare) Last edited by 2.5x_sleeper : 02-27-2008 at 08:48 PM. |
If you go for an after market cat converter, make darn sure the heat shields on it are like the original. The converter is just under and close to the passenger side rubber CV boot, so if you save money with an after market product that skimps on the heat shield, you'll get problems that will offset the savings.
Let us know what you find and prices. I recently replaced both O2 sensors and now have the same code myself at 173K miles. Apparently, the logic looks at the differential O2 and if they are close, the computer assumes the cat converter is at fault since the downstream O2 should be lower once the unburned hydrocarbons get oxidized. |
#6 (permalink) |
Administrator |
Also check out this very informative thread on the P0420 code: P0420 - Catalytic Converter Efficiency Below Threshold
#7 (permalink) | |
#9 (permalink) |
I have the same problem on my Forester 2000. My mechanic quoted me a price of around 1,200 to 1,500. In other states you can get a Catalytic convertor for about $200.00. Only in California are the prices so sky high due to Federal requirement for the catalytic convertors used on cars in the state.
#10 (permalink) | |
Administrator |
We were going to do this for our 98 that needed a new cat, but our shop saved the day at the last minute with a used one they sold us at scrap metal price. |
#11 (permalink) |
when my '01 had the 420 code I replaced the rear O2 sensor and didn't see the code again for quite some time at which point I then threw a universal cat on and all was well. I would say shoot for replacing the rear O2 first, if I remember correctly it was the cheapest part, and see if your troubles go away. Usually you can replace it yourself.
#12 (permalink) | |
![]() BTW, welcome to the forum! ![]() Bobby...
2007 WRB FSXT 4EAT 2003 PBP 2.5X 4EAT +AVO turbo kit! (son's) 1995 Neon Sport (spare) |
