Go Back   Subaru Forester Owners Forum > Technical Forums and Vehicle Assistance > Engine and Exhaust
Old 10-18-2008, 05:49 PM   #1 (permalink)
Default $5 fix
Hi, I have been searching in vain for an explanation of the $5 fix (mechanical) for the PO420 code that I have seen references to. Would someone be kind enough to point me in the right direction to it please?
bbco is offline   Reply With Quote
Old 10-18-2008, 06:12 PM   #2 (permalink)
Gallery: 21
Feedback Score: 29 reviews
Spark plug non-foulers will do the trick... available at your local auto parts store. Here's a how-to from the Evo forum: $5 o2 cheater/non fouler how-to - evolutionm.net
-Silke
04 FXT PP PSM ~ "Subed"
98 Forester S ~ "Slynki"
Old 10-18-2008, 07:10 PM   #3 (permalink)
Need more MODs! Contributing Member
Feedback Score: 25 reviews
A forum search for "sparkplug non-fouler" (with the quotes) will get you to this thread new Cats and O2 sensors
'07 FSXT WRB AT - COBB dyno Protune - Stage 1
'03 X PBP AT +AVO turbo kit! (son's)
Old 10-19-2008, 08:08 PM   #4 (permalink)
Thanks for the info. Do these sparkplug non-foulers come in various sizes/threads? If so, which size would I need?
Old 10-19-2008, 09:26 PM   #5 (permalink)
Yes they come in different sizes. You want the 18mm, either the one with the gasket (crush washer) or the taper seat. If I had to do it over, I'd go with the tapered seat, since the crush washer is a PIA to seat (crush) correctly!
I attached what they look like in a package. The one pictured is the one that comes with crush washers. You should be able to find these at any auto parts store. If you read the info I linked you to, you know you'll have to drill one out with a 1/2" (13mm) drill bit. Start out with one, but you may need both. You only need to drill out one spacer, the one that the O2 sensor screws into. Don't forget to use anti-seize on the threads!
Good luck!
Old 10-20-2008, 05:03 AM   #6 (permalink)
The Modfather
Peaty's Avatar
Rear O2 Sensor mechanical fix for CEL code P0420 - ScoobyMods
Peaty
2010 Legacy 3.6 R - Limited
2006 B9 Tribeca - Limited
1999 Miata - MX5
Old 10-21-2008, 08:44 AM   #7 (permalink)
Thanks once again. Since I reset my CEL a few days ago, all has been well so I'll look for the anti-foulers so that I am ready for the next occurence. I live in Alberta Canada so I expect they'll be available somewhere around.
Old 10-27-2008, 11:52 AM   #8 (permalink)
Anyone know of Canadian companies that carry the anti-foulers? I looked all over town for them on Saturday.
Old 10-27-2008, 12:59 PM   #9 (permalink)
They can be found in most any auto parts store (NAPA, AutoZone, etc) where I live. You need to make sure you ask for a "Spark Plug Non-Fouler" & don't mention anything about CEL issues or using it to space out your O2 sensor. If you do, it will confuse the parts guy & they won't be able to find the part!
Old 10-27-2008, 05:59 PM   #10 (permalink)
I'll look again. Do we have to buy O2 sensors from Subaru or are they a standard item like spark plugs etc?
Old 10-27-2008, 06:28 PM   #11 (permalink)
You can shop for them on the internet if you're not in a hurry. The front 02 sensor (A/F or Air/Fuel) is critical for correct engine operation, so that one I'd pay to get an OEM/factory part. The rear O2 sensor is just used to monitor the CAT, so you can shop around for deal if you need to replace it...:)
Old 10-28-2008, 08:46 AM   #12 (permalink)
I notice a few rear O2 sensors on Ebay, various manufacturers. Anyone have any recommendations. It would be nice to have one with the correct connections on it I suppose. Soon I'll be on my back in the snow here :(
Old 10-28-2008, 10:08 AM   #13 (permalink)
The Modfather
Peaty's Avatar
2001 Subaru Forester Oxygen Sensor | Drivewire.com
Peaty
1999 Miata - MX5
Old 10-28-2008, 05:49 PM   #14 (permalink)
To tell you the truth, I bought both front & rear O2 sensors from my local dealership. Yes, it was more expensive, but I know it's made for my '03 & it will fit as well as work correctly.
Old 10-29-2008, 03:29 PM   #15 (permalink)
For any other Albertans on here, I found the anti-foulers at NAPA. They didn't have 18mm ones in stock but have ordered them for me. Should have them tomorrow.
Bobby, I will probably also get mine from Subaru, at least the first time. :)
