As per COBB's stage 2 map notes:
Revision Notes:
1.01 – The calibration has been updated to eliminate the overboost conditions whenthe car is driven under heavy loads or held at WOT from too low of an RPM. Turbo controls were also enhanced to help prevent an overboost condition.
1.00 - Original Mapping. Adjusted Fuel, Ignition Advance, Boost Control, Camshaft Phasing (AVCS), closed loop control, knock corrections, throttle mapping, and base programming logic. Revised Closed Loop management (REFLASH MAP CHANGE) for improved drive-ability. Smoothed out boost related values, improved boost response at lower RPMs. Altered intake camshaft phasing parameters in an effort to improve low and midrange
torque and boost response. Smoothed ignition advance mapping for low and mid RPM response.
Yeah, there is no 1.02 revision that I am aware of.
